Selling my 2yr old CM Cavalier 3 cabinet;
Color----------------------------------------Black
Dimensions--------------------------(W)202 x (H)435 x (D)500
Weight------------------------------------- -10.4kg
Material---------------------------Aluminum Bezel, SECC Chassis
Motherboards----------------------------ATX; micro ATX
5.25" Drive Bay---------------------------5( Exposed )
3.5" Drive Bay------------------------1(Exposed),4 ( Hidden )
I/O Panel--------------USB 2.0*2, IEEE 1394*1, MIC*1, SPK*1,(Support HD Audio)
Cooling System---------1*80mm Front Fan (Intake), 1*120mm Rear Fan (Exhaust)
Expansion Slots-------------------------------7
Here:
Cooler Master - Ultimate provider of Computer Case, Cooler & Power Supply
The cabinet was purchased from SMC International, Delhi for 4.2k during May '06;
I'd attempted a few mods on this one out of which some turned out being good and some very bad, so I leave it for the pics to speak out the same;
Few gripes in the cabinet:
1. At the top; paint has gone; requires repainting;
2. At the inside; plastic latches; due to the usage of thinner for removing the paint there, the plastic dissolved itself :ashamed:;
3. Back-plate for mounting the motherboard; some holes were drilled for using zip-ties for a better cable management; these holes were not drilled according to the proper dimensions; some metal was cut near the PSU are for letting the 24pin ATX connector to be managed across that;
Pics:
Few good things:
1. The front bezel looks perfect; no scratches, no paint;
2. The side panel has a 120mm hole [near CPU] and an 80mm hole [near gfx card] cut in the acrylic sheet;
3. A 120mm hole was cut in the acrylic sheet placed on top;
4. Some Autografix bullet hole stickers.
My suggestion:
Do a total repainting inside [like how KMD does] and on the top and the cabinet looks much better.
Shipping:
Shall be done thru DTDC ground; Have the original box with me; Shipping ~150 bucks or as actuals;
PM me if anyone's interested; Scammers pl keep away;
Here:
Pics:
Few good things:
My suggestion:
Shipping:
