kidrow
Hi all,
I have a Dell Inspiron 1564 laptop which is about 2-3 years old. The problem I'm facing right now is that the laptop just won't power up/ boot up.
Current Status - Right now, if I turn on the power adapter, the battery led on the laptop comes on briefly for less than a second & then goes off. The green led on the adapter itself remains on/green. When I press the power button on the laptop with or without the power adapter connected, the power led on the laptop comes on. There are no beeps, clicks or any other sounds. The power led on the laptop will stay on until I press the power button again. Also, the laptop starts heating up on the side where the exhaust vents are while the power led is on.
Recent History - For a few days prior to this, the laptop started running excessively hot. Also, the time would get changed incorrectly quite frequently. I also had the right click button stop working many months back. I don't know whether all of these issues are related but I thought it best to mention them.
Yesterday - Now yesterday, my laptop was on for an hour or so during which time my battery drained completely & the system went into sleep/hibernate. On re-starting the laptop off of the mains, the Dell diagnostics program ran {I cancelled it at the point where it said that further testing might take up to 30 mins} & it indicated that everything is OK. Shortly after, I got a BSOD & before I could read what the error was the laptop went dead.
I called up Dell support & the Rep said that it's a motherboard issue which would take Rs. 11000/- to replace.
Queries -
1. Is the Dell Rep correct in saying that the fault is with the mobo?
2. Is there a possibility of repairing a motherboard in such a scenario rather than replacing it altogether?
3. Would any 3rd party repair service be able to fix it reliably for less? Can someone please recommend such a service in Mumbai?
4. Would this laptop in the current non-working state fetch any money? If yes, approximately how much? I'm trying to gauge whether it's worth spending on repairing this or whether I'm simply better off getting something for it & buying a new one at ~20kish.
Many thanks for your time. Much appreciated.
Queries -
