6Pack,
my mistake i made this up as two problems but its same problem. it as i said issue with keyboard n mice both.
Both of them have someplace rubber getting worn off, some places the rubber sticky issue happens.
true with complete plastic surface nothing like soft moist cloth, it works like magic. But on rubber if you try to rub n clean anything rubber starts giving away when you rub on it.
My Razer Mamba front both buttons I had to really clean that rubber coating off. Rubber looks and feels awesome at start, then it look hedious. I patiently scratched traces of all rubber to make it worthwhile.
But i suppose eventually nothing beats plastic or metal.
Will try your talc method too. Thanks
