Bitlord question - plz help
anfjavid
guys. plz give an idea
i have xp and vista.
I am downloading a 1gb file under bitlord in xp and its 50% downloaded.
Now i want to resume the downloading of the bitlord file under vista. That is in vista i want to continue downloading the same file from 50%.
Is this possible ?
If so plz tell me how....
Save the torrent file on your pc. Boot into Vista and double click on the torrent file. When it opens in Bitlord, point it to the same path where the 50% downloaded files are saved. Your download will resume from the same point.
Right... and the best thing is, I think it works for all torrent programs across OS/platforms in general no? When Im booted in Windows I use utorrent this way, then when Im in Linux I point KTorrent to the same files so I dont waste time downloading... you just have to configure all of them to either not append a custom extension to in-progress files - or use the same extension for all...
