Asus p8z77 v pro - not able to enter BIOS
Discussion in 'CPU/Mobo Corner' started by Akash, Jul 4, 2012.
  1. Akash
    Offline
    Akash Upgraded User
    And what about an Asus p8z77 v pro
    It's BIOS isn't opening on boot as well with my 120gb Intel 520 series it giving write or read speed of 110mb
  2. myth
    Offline
    myth Upgraded User
    Is your keyboard connected to a USB 2.0 port? That helps. When the PC boots tap the NumLock key a couple of times to see if it is detected during boot time. If not, then swap ports till it is.
    As for the transfer speeds, are you copying a file between your HDD and SSD? If so then these values look normal, else try the benchmark again using a Synthetic benchmark suite like Atto or Crystaldisk.
  3. Akash
    Offline
    Akash Upgraded User
    Sire the keyboard is connected properly bcoz after booting I play games on it
    SSD to same ssd
  4. Akash
    Offline
    Akash Upgraded User
    Bhai help me yaar now it is not able to boot also
    Only a red light beside graphics card is on
    And beside ram slot
  5. myth
    Offline
    myth Upgraded User
    Perform a CMOS reset.
  6. Akash
    Offline
    Akash Upgraded User
    Now it's not starting also
    The red light beside gpu and ram blinks
  7. nRiTeCh
    Offline
    nRiTeCh ╙TÉçhkⁿºwªy±iVé»╖
    You bios might have conked up. Use asus cd/dvd you received with the mobo and boot using it and reflash bios...hope that helps.. Just indert it and boot your system and keep pressing press f8/f9 key. Refer to the manual for the exact set of keys and beeps for successive boot or flash.
    If theres no display on your system as of now, download asus recent or stable bios version along with its bios boot files from your friends place and ofcourse from asus site, put them on a pendrive and during poweron keep pressing f9 or f8 key(refer manual) to boot directly from pen drive. It will automatically flash your bios and restore it and hopefull all goes well... This procedure takes 3-5 mins.
    Report after trying this.
Similar Threads
Forum Title Date
CPU/Mobo Corner Asrock z77 extreme4 vs asus p8z77 m-pro Nov 3, 2012
CPU/Mobo Corner will a cooler master hyper 212 evo fit on asus p8z77 m pro? Apr 23, 2012
CPU/Mobo Corner Asus Z87 Deluxe/Dual motherboard unboxing :top of the line hardware with thunderbolt goodness. Mar 31, 2014
CPU/Mobo Corner Asus A88X-Pro FM2+ Motherboard unboxing. Mar 31, 2014
CPU/Mobo Corner Asus H87 pro and some questions Nov 16, 2013
Share This Page
