write2anandsharma
Which mobo is best in terms of OC capability, quality, features etc.
Asus is Rs. 400 dearer and is m-atx.
Asrock is 8+4 while asus is 6+2 in Digi power design. So how come oc capability of asus is better. More dearer versions of asus like z77-v has 8+4. But asus also has something like VRM which asrock dosent. So its fairly confusing for me.Go with Asus P8Z77M-PRO,It has better built quality,Less issues than AS Rock Z77extreme4,Also overclocking capability is good on Asus Z77M-PRO.The M-ATX factor doesn't mean you will have trouble,Everything will fit fine,Cheers
If asrock extreme 6 put in the mix which will fair.
